Binary file is greyed out in Write Measurement File express VI.
I am running labview 8.2 on Fedora 7 Core.  I have also installed it on an earlier version of fedora that was in line with the supported red hat distribution.  The problem is that when I try to use the Write Measurement File express VI, the binary file option becomes greyed out after the dialog box opens up.  It is present for a second but it is impossible to select.  When I have tried bringing over a vi written in Windows (where the binary option was available), the option is also disabled.  I am trying to avoid writing the file out in lower level code since I want to use the auto file name generation available under the express VI.  If any body knows a workaround or has some sample code that writes out a new file for each measurement with the date and time in the filename let me know.
(2,364 Views)
Hi Ikiller,
Is this still occurring?
Could you please provide a screen shot to show the behavior?
Thanks!!
Aashish M
CEO
TransferFi
www.transferfi.com
(2,343 Views)
