04-08-2008 05:39 AM
04-09-2008 05:57 PM - edited 04-09-2008 05:57 PM
testmyhardware,
You can use the shipping examples to help get you started. Begin by going to Help > Find Examples.
Is Synchronization important between the two cards or are you just looking to acquire from all the channels?
If you need to synchronize the two devices then you will need a RTSI cable to connect the two cards. You can then use our Synchronization examples to help get you started.
Then navigate to Hardware Input and Output > Modular Instruments > NI-SCOPE > Synchronization
Otherwise you can just combine one of the generic examples.
Hardware Input and Output > Modular Instruments > NI-SCOPE > General > niScope EX Getting Started.vi
Here is what my code looked like after I combined the above example.
04-14-2008 01:05 AM
Hi Ryan,
Thank you for the information. I will try this and get back if I face any problem.
Regards
