.tdm file storage vi's slow editing vi's
I am developing software using Labview 8.5 and have recently added some file storage vi's for the .tdm format for use in DIAdem 10.2.  Upon using the open storage, set file properties, write channel group, write channel, and close storage vi's, the editing has become extremely slow - for any operation I try to perform there is a 10-15seconds delay before it occurs.  If I remove the .tdm vi's from my diagram then the editing goes back to normal and changes/operations occur almost instantaneously as expected.  My project is not large as far as I am concerned (Front panel - 121k, block diagram=1538k, code=0.2k, data=957k, total=2617k, total vi size on disk=389k)
I saw a similar post to the .tdm storage vi's causing this to occur back in 2005 and was supposed to have  been on the fix list but it does not appear that it has 3 years later.  I am sure many others are using these vi's so not sure what I may have done differently to cause the editing to slow down so much.
Anyone with ideas and fix would be greatly appreciated as I cannot afford to sit around 10-15 seconds for every step of my developement.
(2,400 Views)
Yes, sometimes Storage VIs are slow. But They are Express VIs, supplying the easy configuration for users. If you feel they are too slow, I suggest that you can use TDMS files instead.
(2,375 Views)
