Binary output at the digital output pin as 1111 1111 1111
Hi
 I am using DAQ 6009 and i need a output as 1111 1111 1111 at the digital output(12pin )of the DAQ.Please give an idea or a vi to do so
Thanks in advance...
(2,996 Views)
Accepted by topic author DKLabView
Hi DK,
look in the example finder for suitable example VIs...
In general: Open/Create a DAQmx task, select all DO lines, output TRUE for all channels...
(2,992 Views)
It seems that you want to generate static value(s) on 12 pins of USB-6009. Find attached example and let me know if it helps.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,988 Views)
i want generate 4 sets of values at output
1111 1111 1111
1100 1111 1001
0000 1111 1001
1111 0000 1111
(2,975 Views)
Hi DK,
so you have to call DAQmxWrite four times. Well, you could use a loop to do so...
(2,972 Views)
