Bit error rate and latency for 2x2 MIMO LTE system
I am using Labview communications 2.0 with LTE framework 2.0.1 for simulation of 2x2 MIMO system using 2 USRPs and 2 computers.
How can the bit error rate and time latency be measured for this system setup?
(2,810 Views)
I do not think that anyone here would be able to give you a general answer to your question. The latency and bit error rate depend on many factors, such as the modulation scheme you are using, the error coding etc... Please find a tutorial on http://www.ni.com/white-paper/53286/en/#_Toc454877541 which could help you compute the values that apply for your setup.
(2,733 Views)
