I have run into what appears to be a labview bug. This is the second time I have encountered this problem, both times it has been on the tab control.
I was just modifying some block diagrams, and when I went back to the front panel, I get a grid of thick black lines. Also, if you move control around, they leave 'artifacts' behind. I tried closing the app, ect, assuming it was just a screen redraw problem, but it didn't go away, so I tried copying it onto another computer, and I got the same problem on anotehr computer.
Everything seems to be functioning, it is just a display problem. Has anyone had experience with this? Also, if you download this VI, and cannot see the black lines on the front panel, let me know.
The VI is ElectrodeEditor2.vi. You will need the database connectivity toolkit to open it.
Alex~
Attached is teh vi and subVIs (741k)
