Blackfin 537 LCD Example
I currently am working with the BF537 Ez-Kit lite attempting to integrate a LK204-25 Orbital Matrix LCD via TWI as in the Blackfin example provided with the developer kit. I have power and ground hooked up properly via the TWI pins but regardless of which pins I attach TX and RX to on the TWI I cannot sucessfully get text to print to the LCD. Any Suggestions?
Mead96
(3,123 Views)
Hey Mead96,
I would suggest opening up the Example Finder (Help -> Find Examples) and search for Blackfin. Browse down the list to find TWI LCD.lvproj. This is similar to the example that you are trying to build, using the Orbital Matrix LK204-25 LCD.
Also there is a great tutorial called the LabVIEW and Blackfin Interactive Demo. A great way to make sure all the programming is right!!
Hopefully this helps.
Aashish M
CEO
TransferFi
www.transferfi.com
(3,090 Views)
