Changing colors of particular lines in a text indicator
Is it possible to change text colors of particular lines in a text indicator?
I have a text indicator which displays test results. I want to color particular lines according to the test status, green if test went ok, yellow if it was skipped or had warning messages and res if it failed. How may I achieve this?
Thanks for your time!
Have a very nice day!
Message 1 of 27
(4,432 Views)
Have u searched the forum?
see here, here
search and let us know if still some help required.
Mathan
Message 2 of 27
(4,424 Views)
Hi rashid,
there are property nodes for (first step) select parts of the text and (2nd step) change the color of the text selection...
Message 3 of 27
(4,422 Views)
Yes I did search using the same text as the message text above, but it yielded some useless results. But, anyhow, thanks soooooo much for the links. The very first one solved the problem. Thanks Mathan, thanks a lot.
Message 4 of 27
(4,417 Views)
Rashid, Smiley Happy
Glad to help you Smiley Wink
Mathan Smiley Very Happy
Message 5 of 27
(4,415 Views)
Thanks GerdW! The posts Mathan pointed to had some example VIs. I downloaded them and they showed the way practically, just as you just said.
Thanks for your time.
Message 6 of 27
(4,408 Views)
Thanks Mathan!
Its always great to know that there are friends out there ready to drag you out of trouble. Thanks for always being there when help is needed.
Have a very, very pleasant day!Smiley Happy
Message 7 of 27
(4,391 Views)
But the star rating is not good enough for evaluating things......
Message 8 of 27
(4,387 Views)
Would this do?Smiley Wink
Message 9 of 27
(4,375 Views)
It is customary to give 5 stars to say thank you.  Less than that can be interpretted differently as in it didn't help.
Please do not rate this post.
Thanks.
Mathan, we'll help "fix" the rating 😉
Message 10 of 27
(4,357 Views)
