Blackfin Data Type question
I've been using Labview Embedded software for Blackfin targeting the Blackfin 537 EZ lite kit. I have a basic question with regards to Labview dealing with Blackfin data types. I have an example code screenshot attached which gives a better idea about my question. The actual icons do not appear beacuse this machine does not have the mbedded software but regular labview software but I hav ethe name of the functions that I used. Basically, was trying to use this for simpl audio signal processing but for me to do any processing I need to understand the data type. So if you see the 'BF Seperate Audio channels.vi'(highlighted in red) it has a left and right output. So if i just passs these to the inputs of 'BF Combine audio Channel.vi'(highlighted in green to the right) I can hear the audio good but if I do any kind of math to these lines the output is noisy and inexplicable. I would like to know waht type of data this is and what i need to do for som math manipulation (For Eg. multiply to amplify the volume and divide to reduce the volume etc.)
-Sreekar
(2,742 Views)
Duplicate post here.  Please refer to that DF for further answers on this topic.
Nadim
Applications Engineering
(2,733 Views)
