On and Off signal
Hello, I'm trying to do a life test for air valves and I want a ON ang OFF cycles.
The estemated time for this test is about 5 days. What is the best way to do this.
My circuit (valve driver) requires 0 vdc for ON and 10 vdc for ON.
Any help will be appreciated. Thanks!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(2,987 Views)
What kind of DAQ hardware do you have available.
You can generate a square wave with the Analog Out.
(2,968 Views)
I'm using PCI-6024E with SCB 68.
So square waves from 0-10vdc will do. All I need to figure out is to put the ON/OFF time intervals.
I'm thinking to turn the valves ON for 30 sec then 5 sec OFF.
Thanks Arvin!
______________
KowdTek
LabVIEW 2009
(2,955 Views)
Hi Flip Tek,
Another option is to output an analog value, and update this as needed. To build upon the times you listed, you can output a 10v signal for 30 seconds, and then a 0v signal for 5 seconds, and have this sequence repeat (see picture below).
Message Edited by David L. on 08-08-2007 12:05 PM
David L.
Systems Engineering
(2,929 Views)
