Block Peak Detection and Display
I am doing a project on a spike check automation program in Labview. I am trying to detect the peaks and valleys from a probe test on a wafer.The probes are attached to the wafer and connect to an oscilloscope. Right now finding the peaks and valleys are done manually but take a lot of time from one pin.
My program has to optimally run for 20 seconds and, at every interval, of let’s say 20microseconds, has to take the worst case scenario for the peaks and take the screenshot from the oscilloscope and save it until the worst case scenario in the next block on 20 microseconds until the 30 seconds are up.
I am using LV 2010 and I don’t have experience with LV before. I have researched and found a VI called waveform peak detector which seems helpful but I am not sure how to save a screenshot at each interval or block.
I am also unsure on what to put in a loop so my program can run continuously for 30 seconds without stopping.  I also have the instrument drivers for my particular oscilloscope so I can control the scope from my computer and LV program.
Any help is appreciated and thanks in advance for your assistance.
(2,703 Views)
Share for care... oops share for cure...!!
please share your code or more info..!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,655 Views)
