i2c with WLS-9205
Good afternoon.
I wonder if it is possible to make a i2c communication with the wireless data acquisition card WLS-9205. I want to connect several IMU sensors with this card, to receive data via WI-FI. Thanks
Regards!
(2,659 Views)
Hello Mr. ElectroUnited.
First, welcome and very thanks for your contact to the NI Discussion Forum.
Well, your hardware doesn't support I2C communication.
You should use HSDIO 655x or NI 8451 for the application.
Look for this links to know more detailed about this communication type:
Serial Protocol Communication Reference Design for Digital Waveform Devices
https://forums.ni.com/t5/Example-Code/Serial-Protocol-Communication-Reference-Design-for-Digital/ta-...
I2C Digital Waveform Reference Library
https://forums.ni.com/t5/Example-Code/I2C-Digital-Waveform-Library/ta-p/4229934
I hope helped you.
Best Regards,
Wesley Rocha
Application Engineer
National Instruments Brazil
Visite a nossa comunidade em PORTUGUÊS!!!
Certified-LabVIEW-Associate-Dev
(2,618 Views)
Based on your requirement you might need:
1. Right hardware that supports I2C communication Wesley_Rocha correctly specified, it could be either HSDIO 655x or NI 8451 and this will provide communication with various IMU sensors.
2. WiFi network (you don't need a WiFi DAQ card), so that you can send the data (acquired from IMU sensors using I2C communication) to any other system over the network.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,614 Views)
