Block diagram editing slow
A very crude way to create subVIs is to simply select logical groups of code, then do "edit..create subVI" (Be aware that if your selection contains e.g. property nodes or local variables, the outcome might not be very pretty).
Otherwise you simply need to invest some time to learn LabVIEW basics (some subVI related information can be found here). It does not make sense to start a big project with so little knowledge.
I would still recommend that you show us your code. Maybe we can give some more specific advice.
Message 11 of 48
(2,728 Views)
Hi Ranjeet Singh,
           I said now i'm comfortable in doing subVi, so going for that and hence my VI size will be reduced. Then why do you need my VI..?? Even after reducing the size if problem remains, then I will come back to you with my vi.
Thanking you,
Sushmith
Message 12 of 48
(2,725 Views)
If you create an oversized program with little LabVIEW knowledge (you don't even know about subVIs!), chances are that there a many (many!!!) other problems. Unfortunately, if we cannot see the code, we cannot give more specific advice on how to improve it. Many veterans on this forum have "seen it all" and can probably give you very valuable feedback.
It is in your best interest to show us the code, but nobody forces you to do so. We simply cannot help you past very generic advice if we cannot see what you are actually doing. Your loss!
Message 13 of 48
(2,718 Views)
Hi
Thanking you,
Sushmith
Message 14 of 48
(2,717 Views)
Like you said in your previous comment -'So edit my vi in such a way that its size reduces.'
This means you are asking someone to edit.Looks like you want to say editing my vi.
Using subVI may reduce the problem but what everybody want to say is remove the redundant code, try to optimize code, do less computation and all that
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 15 of 48
(2,717 Views)
Hi
Thanking you,
Sushmith
Message 16 of 48
(2,713 Views)
It really scares me when programmers that don't even have basic LabVIEW certification work on defence projects.
Most likely your company has a few experienced programmers. Why don't you ask around?
Message 17 of 48
(2,706 Views)
Hello
Thanking you,
Sushmith
Message 18 of 48
(2,700 Views)
Hi ranjeet,
                I meant I will edit my vi, sorry for misunderstandings.
Thanking you,
Sushmith
Message 19 of 48
(2,698 Views)
@sushmith_ks wrote:
Hi ranjeet,
Friend,
          What we want to say is if in your VI there are multilple task is there then why cant you divide each task into subVI and then try to post that problem in this forum. Afterall a good programmer always try to break the large code into small pieces as it is very simple to attack the problem if it is small.
One more thing your VI looks is really scary. If you are trying to optimize this code then this will take ages. Break your VI into subVI and make sure input and output of subVI is working fine. This will take less time. This is called modular programming.
Go to page 6 and 7 of attached ppt. That is what I mean to say
--Ranjeet
Message 20 of 48
(2,676 Views)
