Block diagram editing slow
@sushmith_ks wrote:
Hi
Spoiler
This is very worrying.
The white "dot" is a full screen size.....
The mind boggles....
Message 21 of 48
(2,374 Views)
@Ranjeet_Singh wrote:
Go to page 6 and 7 of attached ppt. That is what I mean to say
If you quote or attach work that you did not create, you should always give proper credit to whoever wrote it als also include a link to the original source. There is no need to attach something that can be downloaded from elsewhere.
Message 22 of 48
(2,334 Views)
That's exactly what I thought.
I imagine the number of Rube Goldberg Codes in this VI.
This is really worrying.
Mondoni
Message 23 of 48
(2,326 Views)
Sir,
     I just want to show him what I mean to say. It will take sometime to search the ppt and read, If I attached some example then this not bad. I tried to save his time only. He is in defence project so I dont have any rights to say good or bad of somebodys code.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 24 of 48
(2,303 Views)
Sir,
Cultural differences aside, the fact that he's ina  defence project certainly does not prohibit us from informing him of the quality (or lack thereof) of his code.
Bad code is bad code, no matter what the purpose of it might be.
Message 25 of 48
(2,282 Views)
Sir,
Friend @Intaris,
what I mean to say is not because of defence instead we dont know the purpose and application of the VI. Untill and unless I know all the application and purpose I cant say bad because there may be only this way (You never know).
--Ranjeet
Message 26 of 48
(2,275 Views)
Hi everyone,
          That is what i thought, it is the only way. because system needs so many tasks to be done in my VI. and most of the variables are used in many places, and few of them are used in many tasks. So if I create subvi,updating value will be a problem since i cant go for local variables. For this reason, i splitted up everything and ended up in creating a huge block diagram.
        Eventhough i succeed in creating subvi, my block diagram size can not be reduced to greater extent. because as I said tasks are more, and in few places i cant go for subvi.
Thanking you,
Sushmith
Message 27 of 48
(2,266 Views)
No, there is always more than one way!
Message 28 of 48
(2,257 Views)
If it turns out that this is the ONLY way to get his program doing what he wants then I will stop programming LabVIEW immediately and devote myself to a completely new task....
What I'm trying to say is that looking at the image posted, this certainly is NOT the only way.  In fact, most other ways are probably better than the one chosen, but if the willingness to learn is present, then it's at least a great way of learning.  That is certainly a possible positive outcome of this exercise.
Message 29 of 48
(2,255 Views)
         As I mentioned in the beginning, I was a fresher when I started the Vi, after thinking so much I came to conclude that its the only way. It doesn't mean that its the ONLY way, but I could do only that much.
Thanking you,
Sushmith
Message 30 of 48
(2,251 Views)
