Block diagram messed up
@pincpanter wrote:
But probably this will not work.
yes also it doesnt work
Message 11 of 22
(1,528 Views)
Is it possible for you to attach the actual VI?
Message 12 of 22
(1,504 Views)
Actually i cant share all, but i can share a part of the vi. You can find it attached.
Message 13 of 22
(1,481 Views)
Hi ocan,
LabVIEW comes with several inbuilt tools to "measure" VI quality.
One of them is Tools->Profile->VI metrics…
This is its report on your VI:
Your VI clearly is too wide ("Breite" = width)!
LabVIEW only allows (max) 16383 pixels for width and height, the StyleGuide recommends to limit block diagrams to just one screen!
Get a working backup of your VI from your backup system (aka SCC tool) and your problem is gone…
Message 14 of 22
(1,473 Views)
When i check it, it doesnt seen that large.
Also can you please share how to do it?
Message 15 of 22
(1,465 Views)
Hi ocan,
  • Get the backup media, where you stored safe copies of all your work in regular intervals: choose an older revision of your VI from those backups and get it.
  • With SCC tools (Source Code Control) it's much easier: here you can use a menu to "checkout" an older revision of your VIs from your "repository" (terms refer to SVN).
When you don't have backups nor did use any SCC system then you learned the importance of both now the hard way!
Message 16 of 22
(1,467 Views)
I dont have any backup actually. Is there any way to fix that vi?
Message 17 of 22
(1,462 Views)
Hi ocan,
No backups?
You can "fix" this VI by recreating it from scratch… (Use the documentation you wrote for your VI or whole project to remember all the functionality you put into this VI.)
Message 18 of 22
(1,458 Views)
unfortunately no. I think i need to start from top
Message 19 of 22
(1,451 Views)
Hi ocan,
Before you start coding you should implement a SCC tool. Or atleast setup a backup strategy. Really!
Message 20 of 22
(1,443 Views)
