Block diagram style is not the style I set for the front panel, LabVIEW 2022 Q3.
@aeastet wrote:
If you go to the options for LabVIEW you can set the default to what ever you want:
Read the 1st post again.
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 13
(253 Views)
Thanks for this but I did say in the very first thing in my post I already did that, it's because the front panel of the DAQmx is in a different style to what I chose as default and I can't change that.
Message 12 of 13
(224 Views)
@l5546 wrote:
 possibly something NI could work into a new version to change the DAQmx front panel items to whatever you choose as your default style across the board.
Hopefully not.
Message 13 of 13
(203 Views)
