Block diagram to pdf file: help
Could someone who has LabView with the NXT toolkit turn the block diagram of this file into a .pdf file, so I can use it in my powerpoint??
(4,438 Views)
What do they teach in middle school these days?
Back in my day it was a Plato II
help the grade school student out guys... there isn't enough processor in my phone to open a vi and take a snip. Supplementary info revealed via pm. STEP Education may be at work.
good luck wenzel
(4,406 Views)
Extra kudos for anyone who links the vi viewer for Mobile
idea exchange thread
(4,405 Views)
I don't seem to have all the subVIs, so here's the best I can do at the moment.
(4,393 Views)
I also don't have it currently installed on my own pc.
I'm currently downloading it and I'll let you know when I have it installed and activated.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(4,328 Views)
I've tried to open it, but I also seem to have issues at my side.
I think the fastest way would be to go to the following part of the forum:
http://forums.ni.com/t5/LabVIEW-for-LEGO-MINDSTORMS-and/bd-p/460
Those people will have the right software installed and should be able to help you directly.
Kind Regards,
(4,313 Views)
Accepted by Wenzel31
I found someone who solved it for me. Sorry for annoying you with my problem, i was panicking, but everything's fine now.
Thanks, and sorry again
(4,282 Views)
