Blockdiagram of a PID controller
Inorder to work properly for the below attached pid controller frontpanel diagram what will be the blockdiagram????PLz help.
Thanks as kudos only:)
(5,546 Views)
umm.. what? Are you asking us to write your code? Really?
Perhaps you should spend a little time doing some search on this site for PID controllers. Or perhaps you may want to look at http://sine.ni.com/nips/cds/view/p/lang/en/nid/209054
(5,520 Views)
I strongly suggest you to install the LabVIEW Control Design and Simulation Module (if you are academic, you probably have this already - talk to your System Administrator) and you should look into this "tutorial" below:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4ToCAI&l=en-US
This should not be very difficult.
Barp - Control, Simulation, RTT and HIL - National Instruments
(5,509 Views)
Hello Barp,
                I went through the tutorial in the link suggested by you.But Iam confused how we will use our own transferfunction instead of H(S) in that block diagram.
Thanx.
(5,477 Views)
Accepted by danil33
If you double-click on the Transfer Function block, you can select From "Terminal" or "Configuration". If you use Configuration, it will allow you to enter the information directly in the block with creating an external model.
I would strongly recommend also see those resources below:
http://home.hit.no/~hansha/documents/labview/training/Control%20and%20Simulation%20in%20LabVIEW/Cont...
http://multimechatronics.com/images/uploads/tutorial/LabVIEW%20SimulationTutorial.pdf
http://zone.ni.com/devzone/cda/tut/p/id/5855
Hope this helps.
(5,439 Views)
thank USmiley Very Happy
(5,419 Views)
