Blocks
What do you call these blocks? Thanks 🙂
Message 1 of 8
(6,405 Views)
hi,
      you mean name (Bundle By Name or Bundle)
Message 2 of 8
(6,375 Views)
I mean where to find those blocks (palettes) and what is the specific name of those blocks. thanks 🙂 Referring to the picture I posted.
Message 3 of 8
(6,364 Views)
Hi nerudorin,
Reciprocal is a basic numeric function, Bundle deals with clusters…
I guess you already know the beginner tutorials for LabVIEW?
Message 4 of 8
(6,356 Views)
Another  thing, how to put this value in the bundle? (referring to the attached picture) thanks 🙂
Message 5 of 8
(6,351 Views)
Accepted by nerudorin
Hi nerudorin,
this "thing" is a simple numeric constant…
Well, usually by using a wire… 😄
Again: Have you taken the free online resources to learn LabVIEW?
Message 6 of 8
(6,347 Views)
I also suggest the free training.  But also if someone tells you the name of a function, you can search for it.  Right click to open your palette and then click search and find the function.  Then it will open your palette showing you where it is.  Of course if you know what it is and where but just want to get to it faster you can open up QuickDrop by using CTRL+Space then type the function and then click on a blank spot on the block diagram to drop it.  Here's a few more training links.
NI Learning Center
NI Getting Started
-Hardware Basics
-MyRIO Project Essentials Guide (lots of good simple circuits with links to youtube demonstrations)
-LabVEW Basics
-DAQ Application Tutorials
-cRIO Developer's Guide
Learn NI Training Resource Videos
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
Message 7 of 8
(6,266 Views)
Beyond the LabVIEW training (which you should explore before doing anything else in LabVIEW), make life easier on yourself by finding "Snipping Tool" in your Windows start menu.  You can use that to take a quick screenshot instead of using MS Paint to recreate what you're seeing.  It even has a highlight feature so you can show us what part of the picture you're interested in.  Or, as always, you could just attach the VI.
Message 8 of 8
(6,202 Views)
