Blood pressure using Arduino
I tried to solve the ms deflation problem I still couldn't solve it because I don't know labview programming well although I know the solution and I don't know how to apply it
Message 21 of 24
(1,322 Views)
While we know LabVIEW, we still don't know what you want because the problem is poorly defined.
You have not answered my last questions.
Message 22 of 24
(1,302 Views)
then during the deflation of the cuff the pump must be closed and the valve must switch between two states to deflate the cuff slowly for example it will deflate for 2s then it will pause in this state the pressure value must be saved in a table in order to distinguish after systolic and diastolic pressure values.
Message 23 of 24
(1,284 Views)
Good morning,
I am currently working on a project to develop a blood pressure monitor. Being still a beginner in labview, I am having difficulty moving forward with this project.
I would be extremely grateful if you could share with me the final initial version (final VI) of this project. Your help would be invaluable to me in making progress in my learning.
Message 24 of 24
(1,003 Views)
