Bloomy VI Analyzer test file
Hello , I am reading the <<LabVIEW Style Book>> of Bloomy . In chapter 10 ,there are some VI Analyzer cfg tests files , I want to download them in www.bloomy.com/lvstyle but I can not create the account as I can not see the CAPTCHA . Is there anyone can help me to download the cfg tests file ? Many thanks !
(1,511 Views)
Accepted by 清风之刃
One of my favorite LabVIEW books!  When I started learning LabVIEW, I read this book cover-to-cover 3 or 4 times during my first years of LabVIEW (I got sort of "thrown in" to take over a 1000-VI project (lower-case "p") written in LabVIEW 7, totally without documentation.  I ended up rewriting it from scratch, using Design and Style principles learned from Peter.
I just talked to someone at Bloomy, and got permission to download and post the VI Analyzer cfg test file.  Have fun.
(1,475 Views)
Hi, Guys:
    Many thanks for you , but I have checked the cfg file , I found some configuration seems not same with the Style Book said , for example the Book suggest to set the Coercion Dots maximum number on a single wire to 0. but in the cfg file the Single Wire is the default value "2" . I am confused about this , and I don't know which one is the correct ?
(1,449 Views)
The question "Which one is correct?" may be meaningless.  You are comparing what is written in a book published more than 15 years ago with LabVIEW code (probably being used by Bloomy Controls) that can be found on their Web Site.  "Style" doesn't have hard-and-fast "rules" -- are you exactly following all of the suggestions that you find in the LabVIEW Style Book?  In particular, are all of your VIs now fitting on a sincle Laptop screen?
Bob Schor.
(1,428 Views)
You are right , I think I got your point . Thank you very much
(1,422 Views)
