Bluetooth DAQ VI - Converting output from BT device
I am currrently experimenting using a bluetooth daq device to acquire data from instruments and display the outputs in labview. Attached is a trial VI i have been using
I have 2 problems with the attached VI.
1. When I stop the VI running, I can't run it again for a few minutes. If i try I get error code 56 source Bluetooth open connection. If I wait a few minutes and run again, it is fine.
2. The bt DAQ device acquires signals with a 16-bit accuracy in the range of 0- +5VDC. A value of 0x0000 represents 0 Volts, a value of 0xFFFF represents 5 Volts.
Full ASCII mode data flows in the following character displayable HEX format: - SSSS 1111 2222 3333 4444 \n\r
SSSS is a sequence number, starts at 1, rolls at 0xFFFF.
I have the problem of displaying this as 0 to 5 volts on my front panel as I am unsure how to convert back.
Any help with these issues would be appreciated.
(2,849 Views)
Hello jamie310382,
As I am not able to run your code I can only suggest a few things, but I would like a little clarification on what we are working towards.
If I understand this correctly, you will be reading out data from the Bluetooth connection via the Bluetooth Read function. This will come in at four elements at a time and then you need to display the number that this represents and scale it to 5V. Is this right?
I have put together an example for manipulating your string for now, so let me know if this helps.
Kind Regards,
Michael S.
Applications Engineer
NI UK & Ireland
(2,790 Views)
Hello jamie310382,
Did you get a chance to have a look at my example VI?
I believe that the Scan From String function would best suit your requirement at this stage, but if you have other concerns, then please post back and I will try to help as best I can.
I hope this finds you well!
Kind Regards,
Michael S.
NI UK & Ireland
(2,745 Views)
