04-18-2018 10:46 AM
Yes I am a beginner in Labview. I have seen the stop block in labview front panel but that is quite different from the block which is in the pic.so I got confused with that.
Anyways I appreciate your response and helping nature.
Thanks for your help and I will try the solution you have given me.
04-18-2018 02:35 PM
Hi abhishekti,
So take the beginner tutorials!
(And start by learning the correct spelling of LabVIEW! :D)
So you got confused by the look of a frontpanel element and its representation in the block diagram? Please take the beginner tutorials!
That's no offense, it's a suggestion with good intentions. You will make your life a lot easier when you take some lessons before starting to create code with a new IDE. (This applies to any IDE you will use…)
04-20-2018 01:18 AM
I have used NI VISA functions and made the following schematic.But I got this error-
"Error opening resource:
USB0::0x1612::0x0102::NI-VISA-80004::RAW
VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it."
I have attached the block diagram and VISA Test panel.
