Bool indicator is "True" if I connect this indicator to terminal. (In case structure)
Why he is "True" if constant to case is "False"?
Message 1 of 12
(527,691 Views)
Hi Lugaro,
Because you NEVER set that boolean indicators to FALSE.
Because you also made TRUE the default value of those indicators…
Because indicators, which are connected with the connector pane, should NEVER be placed within (case) structures!
Based on your question: Did you take those "Training resources" offered at the top of the LabVIEW board?
Message 2 of 12
(527,684 Views)
 As Suggested by GerdW, you need to go through LabVIEW Basics (https://www.ni.com/getting-started/labview-basics/).
In addition if you want see the execution flow during runtime- Check the Highlight Execution in the Block Diagram.
Message 3 of 12
(527,643 Views)
Because of the magic of dataflow. Follow the wire! Your program does exactly what you programmed it to do. (...and why are you using continuous run"? Since you have no controls, nothing can ever change)
Obviously, you must have simplified your demo ad absurdum. Can you show us a more functional program that shows what you are trying to achieve?
Message 4 of 12
(527,598 Views)
Hello. I repit my simple demo in another file and they show different result. Why?
My original problem is VI for bar-code scaner.
I scan bar-code and wont to see it while I dont use scanner. But string indicator clear in next cycle. Somtime (and today) it work as I wont. Sometime case work evry cycle after start - clear "string" and ON "test" indicator
Message 5 of 12
(527,554 Views)
Thank for "Highlight Execution". But it show that indicator must be "False".
Message 6 of 12
(527,553 Views)
@GerdW wrote:
Hi Lugaro,
Addendum:
Because an indicator, that is connected to the connector pane, is set to its default value at start of the VI execution. That is in contrast to an indicator that is not connected to the connector pane, that will not be changed just by starting the VI.
Regards, Jens
Kudos are welcome...
Message 7 of 12
(527,547 Views)
Message 8 of 12
(527,533 Views)
I repeat my previous reply:
Addendum:
Solution: Make sure, that a return value is always set at the end of the VI execution regardless of case-structures, ....
i.e. in case that "Boolean 2" is your return value, set it outside of the case structure:
Regards, Jens
Message 9 of 12
(527,527 Views)
I try it. Do you have not error?
Message 10 of 12
(527,519 Views)
