Boolean Control inside a While Loop inside an Event Structure
I want to stop my program using a Boolean Control inside a While Loop inside an Event Structure.  Why does this example program not work?
Thanks, Matt
(4,695 Views)
Accepted by Mountain_Matt
Because the front panel is being locked when you press the button and therefore you cannot switch the button back to stop the loop.
In general, it is a bad practice to have loops inside of event structures.  With your very basic example, I would just use a case structure around the code you want to execute only when the button is TRUE inside of your loop; no need for the Event Structure.
(4,689 Views)
Thanks for you help... greatly appreciated!
(4,676 Views)
(4,660 Views)
