Boolean Crossing PtByPt VI
Hi, I am new to LabVIEW and have try to use the Boolean Crossing PtByPt Vi as attached but it does not cross into the stage when I trigger the input. Can you advise? Thank you.
(4,091 Views)
Looks like you are trying to capture the event of a boolean changing. Lucky for you there is a structure to help called an event structure.
See what happens when you make a vi like this:
(4,051 Views)
Thanks, Steven
(4,027 Views)
Accepted by glendale
You didn't attach a VI, you attached an image of the VI.
The crossing probably is detected, but your VI runs so fast (without a wait) that you won't be able to tell. The crossing is only true for one iteration, and that will last for <1 ms.
Run the VI with execution highlighting on. Or put a wait in the VI. Or make the loop stop if the condition it true.
Once you get the problem, step up to the suggested event driven solution.
(3,960 Views)
Thanks, Wiebe
Yes, I get to know where is my problem here, thanks for sharing.
TS
(3,939 Views)
