Boolean LED trigger during DAQ High
My application involves using DAQ to generate the waves for an optical shutter to move up and down. The 'high' state has the optical shutter raised, while the 'low' state has the optical shutter closed. I would like a boolean LED to turn on on the front panel when in the high state, but I am very new to using DAQ and DAQ assistant and do not know how to slip this tiny 'true' statement into the inner workings. Any help would be appreciated!
(1,774 Views)
It is easier to offer help when we see what you have done so far.  That means attach your current VI, please.
(1,739 Views)
Apologies, it is attached below. It's a little bit busy! Under 'Load Pulse Settings for Coordinates' is the DAQ I'm interested in setting the Boolean to the 'high' times of.
(1,724 Views)
