Image Pixel to Inches Conversion Issue
Hello LabVIEW users,
         I am having issue printing the Picture control, the scales configured in the picture control and the print is not matching. I commented the issue in detail in the attached VI (Version - LabVIEW 2017). Please let me know where my scalings are going wrong.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(1,657 Views)
I think the mismatch between the original/actual Image Size (720*780) of the BMP/LV Picture Control, and the Paper Size (850*1100) and the Photo size (being set to Full size in the Printer Preferences), is the root cause of this issue, which eventually makes your printed image look lengthier in the vertical orientation that it originally/actually is.
I think this has got nothing to do with LV's scaling, but that of the printer's. Try adjusting the Printer Preferences parameters & post back here.
- Partha ( CLD until Oct 2027 🙂 )
(1,617 Views)
