How to write continuously to HDF5 file dataset?
I'm using Live HDF5 with LabVIEW to write data read from an oscilloscope to an HDF5. I am reading at 8192 samples/sec and would like to write a new row containing every 8192 samples every second to the dataset. However, it seems I can only write to each dataset once though I might be doing something wrong, so for now I'm writing the data to a 2D array and then once the stop button is pressed writing that array to the HDF5. Is there any way to write to the HDF5 continuously?
(2,266 Views)
Not sure about that library...
I simply copied C:\Program Files\National Instruments\LabVIEW 2020\vi.lib\Utility\MD5Checksum.llb and put the state data in a class's private data. That way, I can add data whenever I want, and get the MD5 hash whenever I want.
(2,255 Views)
Sorry about that. Dyslexia kicking in. MD5 != HDF5...
(2,208 Views)
There seems to be a DataPlugin (Run List DataPlugins.vi with 'web' as source). Not sure if that's what you're using.
Also, post what you have...\
Also see Re: Storing H5 file data as array in Labview.
(2,204 Views)
Trekkie123,
If it is not an issue can you share your vi, only the part where the data from hdf5 is saved to/fro from the array in LabVIEW. I have been struggling to implement it for a few days using the same library (LVHDF5).
Thank you in anticipation.
(2,191 Views)
