Boolean change in array
I have an array of dbl (10k size) that I have the indices for a value in range. the filtered data provides the Boolean result. the next step is to find how many times the data changes from true to false, in addition I need the index of the false condition. I have been unable to come up with or find a solution that provides the necessary data from the array.
(4,583 Views)
Can you back up a few steps, and explain what data do you have, and what data you want?
For example: I have an array of 10k doubles representing the temperature taken every 100ms. I want to find the amount of time the temperature was above a certain limit.
(4,566 Views)
Accepted by rfm1957
Do you need something like this? 
(4,558 Views)
Gregory,
i have an array of data that has been filtered.  The Boolean array provides the indices for the in range result. From the filtered data i need to find the indices of the state change from true to false (in this dataset there should be an array of 12 indices for the array.  I have attached the vi I am currently filtering.
regards
(4,531 Views)
perfect thank you
(4,526 Views)
@rfm1957 wrote:
Gregory,
regards
You don't need the FOR loop around In Range and Coerce because it can accept an array.
(4,439 Views)
