Boolean switch's that are timed
I need to control a heater to be turned on for 60 seconds, and then be turned off for 120 seconds, and then the operation be repeated for a number of cycles. My main loop runs continuously with a delay of 50 ms, and needs a boolean signal from the switch continuously, so there is no possiblity  of placing a wait or time elapsed function in this loop. When I try calling a subVI that has a delay, the output to my main loop would be delayed. Would anyone be able to recommend me in the right direction.
(5,540 Views)
I haven't looked at your code yet, but the Elapsed Time VI doesn't cause your program to wait, so why wouldn't this work?
Cheers
(5,535 Views)
Accepted by topic author prithvibasak
Just do it like this. It initializes False, after time has elapsed, it switches to True, and so on.
This could use some clean-up with the Select nodes, but it gets the job done. This results in False for 120, then True for 60 seconds, rinse and repeat.
Cheers
(5,528 Views)
