linear discriminant analysis
Hello everyone!
I am new in Labview. I would like to implement a linear discriminant analysis.I wanted to know if anyone can pass me an example of any kind that makes me understand how to get started. Thanks so much.
Francesca
(4,776 Views)
 Hi francescabeccarisi,
it looks like LDA analysis is implemented in the LabVIEW Machine Learning Toolkit, which you can find here: https://decibel.ni.com/content/docs/DOC-19328. If you look at the manual, there is a section on LDA Analysis, so I think that should work.
Cheers,
CorraDIT
(4,731 Views)
Thanks so much.
I found somethings. Can i ask if you can explain to me what this program does? Calculates the average of what? Thanks a lot again.
(4,690 Views)
at the bottom of that page there are comments of users about the toolkit. This is a third party toolkit so it's better for you to ask your questions directly there, it's not an NI toolkit.
Good luck!
CorraDIT
(4,682 Views)
If you search the Web for Linear Discriminant Analysis, you can find a number of good discussions that will not only show you how to "do this yourself", but will explain the theory, show you examples, and should help you figure out how to use existing code packages.  At a minimum, it should answer the question "Average of what?".
Bob Schor
(4,667 Views)
