Boot RT on CD w/o Hard Drive
I am considering using RT for something that I am presently doing with
Windows XP Embedded:
- Is it possible to boot LabVIEW RT on CD or Flash and run without a hard
drive?
- Approximately how much disk space is typically required for RT using DAQ,
Ethernet, and Serial Comms?
- Does RT support the LabVIEW Web Server?
- One thing I probably wouldn't be able to do is use the Windows DLL to save
HDF files. Does anyone no how this might be possible in RT?
(3,310 Views)
LabVIEW RT supports LabVIEW Web server applications. LabVIEW RT and DAQ driver typically require about 9.5 MB memory, LabVIEW RT can only be used with RT hardware. I hope this helps.
Best Regards,
Remzi A.
Applications Engineering
(3,309 Views)
Remzi,
What about booting on CD w/o Hard Drive? Can this be done without a hard
drive?
Also, the HDF I mentioned has nothing to do with hardware. There is a
Library of VIs created by NI to support the HDF file format. The potential
problem is that they all call a Windows DLL at the lowest level. Do you
know if the DLL would work with RT?
Thanks - Neal Pederson.
"Remzi" wrote in message
news:506500000005000000D14F0100-1073519706000@exchange.ni.com...
> Hi,
> Best Regards,
> Remzi A.
> National Instruments
(3,309 Views)
