Remzi,
What about booting on CD w/o Hard Drive? Can this be done without a hard
drive?
Also, the HDF I mentioned has nothing to do with hardware. There is a
Library of VIs created by NI to support the HDF file format. The potential
problem is that they all call a Windows DLL at the lowest level. Do you
know if the DLL would work with RT?
Thanks - Neal Pederson.
"Remzi" wrote in message
news:506500000005000000D14F0100-1073519706000@exchange.ni.com...
> Hi,
> LabVIEW RT supports LabVIEW Web server applications. LabVIEW RT and
> DAQ driver typically require about 9.5 MB memory, LabVIEW RT can only
> be used with RT hardware. I hope this helps.
> Best Regards,
> Remzi A.
> Applications Engineering
> National Instruments
