Box plot
Can you please help me find an indicator or subVI for this. I thought it was included in LabVIEW but if so, I can't find it.
Otherwise, surely someone of you have created one before which I would be glad if I could have a look at. Thanks.
(3,414 Views)
May be you need a bar plot?
If so then you have to choose the waveform graph control. Then click on the "Plot legend" (the item at the top-right corner of the graph) and select "Common Plots" item from pop-up menu. There you can choose the bar plot regime of plot drawings.
Also you can change the style of bars at the "Bar Plots" item from the same pop-up menu.
Good luck.
Oleg Chutko.
(3,414 Views)
Thank you but I am well aware of the bar plot and that's not what I'm looking for.
What I need is a BOX plot a.k.a. whisker diagram, used for displaying statistical distribution of data. This can surely not be the first time someone has needed it for a LabVIEW application?
(3,414 Views)
