Brüel & Kjaer 3-ch Input Module LAN-XI - connection with LABVIEW
I've a problem by connecting a Brüel & Kjaer Module (Type: 3052-A-030) to LABVIEW.
Info: The module is connected via ethernet to the PC and is still working with the manufacturer software.
Is there any special LABVIEW LAN driver/software needed?
Best regards, Schall2022
(1,722 Views)
I AM LOOKING FOR THIS ALSO, DO YOU FIND IT?
(1,421 Views)
Any luck with checking with the manufacturer for guidance?
Santhosh
Soliton Technologies
(1,403 Views)
Anyone have any luck with interfacing the LAN-XI / LabShop with Labview?
(462 Views)
Hi
A similar question was asked back in 2011, but got a new life not so long ago :
https://forums.ni.com/t5/LabVIEW/B-K-LAN-XI-module/m-p/1562648
The short answer is, there is no pre-made LabVIEW support from B&K. Read the thread, it is interesting.
There is a programming concept using 'Open API'. And B&K has made examples.
Mainly based on C# and ObjectiveC, so pretty high-level.
'Open API' is a standard, and you can find more about it by google'ing.
Regards
(446 Views)
Thank you!  We have started down this road.
(417 Views)
