DRUCK DPI 610 Drivers
For part of our test equipment used in calibration I use a couple of Druck DPI 610's. I wondered if anyone had done any drivers for this model or had the RS232 Format/command structure required to communicate with it.
Jack
Labview Version 8.5
Labview Version 8.6
Labview Version 2014
Message 1 of 18
(10,006 Views)
So, you're looking for Druck drivers? Shouldn't be hard this time of year, what with all the eggnog flowing...
Sorry, I couldn't help myself.
GE Sensing used to have drivers for the 510/515 on their website but I can't find them anymore, but if you found those I bet it would get you close as it looks like no ones produced any 610 drivers yet.
-Ian
Message 2 of 18
(10,004 Views)
Well it wins on Pheasant beating! (or should that be peasant, which I am!).
Yes I had a look at that link and was unsure if the command structure would be the same. However in between postings I have recieved the format from Druck which is based on their DUCI Protocol. So that's my task over Christmas, joys of working for yourself.
Jack
Labview Version 8.5
Labview Version 8.6
Message 3 of 18
(9,998 Views)
Jack:
Would you be able to post alink to where you found the communication commands/formats for the Druck? Or attach the document if you are allowed.
We purchased their logging software based on CVI, unfortunately it keeps all data in memory then writes the data file when the log seesion has ended. If power is lost or the PC hangs all data is lost. I'd rather write my own LabVIEW based logger since we have lost data in the past.
-AK2DM
Message 4 of 18
(9,991 Views)
Druck did not mention an NDR so I think it is ok. Attached is documents in word format.
Cheers
Jack
Labview Version 8.5
Labview Version 8.6
Message 5 of 18
(9,986 Views)
Jack:
Many Thanks!
-AK2DM
Message 6 of 18
(9,983 Views)
Dear Jack1( and All).
Earlier attachments are missing.
Could anyone please help me with drivers or digital interface specifications for DPI615?
Message 7 of 18
(9,631 Views)
Hi Artem,
I had to remove the documents because general public access was prohibited in my agreement with Druck. If you send me a PM,: smileywink:  I will see what I can do,
By the way the ones I have are for DPI 610 unsure of differences between that and 615?
Jack
Labview Version 8.5
Labview Version 8.6
Message 8 of 18
(9,621 Views)
Jack,
I am also looking for a Druck 610 driver. Is there any way you could send me that document?
Let me know!
Sarah
Message 9 of 18
(9,431 Views)
Hi Sarah,
Yes can do if you send an email address by PM and I will attach PDF's.
Jack
Labview Version 8.5
Labview Version 8.6
Message 10 of 18
(9,419 Views)
