07-30-2016 02:26 AM
Dear Jack.
I'm also looking for some instructions (commands manual) or drivers for DPI615 calibrator, mainly I would like to readout values or at least files from calibrator.
I have some LV experience with Druck DPI150 and PACE, but for DPI615 I do not have any datasheet or manual to build driver. I believe that in basics it should be similar to DPI 610.
If you can share these instructions or diver I would be very thankful.
Kind regards. Jure
07-12-2017 09:09 AM
I know this is an old thread.
I have a DRUCK DPI620 and would like to be able to connect to it and pull live data. Does anyone know how?
09-17-2020
09:58 AM
- last edited on
12-04-2025
06:06 PM
by
markwni
It is possible to control the DPI620 over a serial port connection to a PC using DUCI commands. Use a USB to US232 converter on the USB A port on the 620 (not the mini-USB port). COM port settings 19200 8N1, CR+LF termination, DUCI programming commands attached.
[Document removed at request of manufacturer.]
11-07-2022 03:47 PM
Hi Jack,
Sorry for bringing up such an old thread, but I'm looking for the DUCI protocol to use with my DPI 610... I read that you had to remove the original link to the file, if possible, could you share the info about the protocol in some other way ??
11-11-2022 03:48 PM
Hi Jack, sorry to bother you, but can you still send the PDFs about the protocol ? I've sent you a PM.
Thanks !!
10-22-2024 06:02 AM
Hi Andrew,
do you mean USB to RS232? If not can you supply a link with the proper cable. if Yes how should I connect from serial rs232 to usb A port pins TX RX and GND to GND D- and D+ of usb?
Thank you!
10-22-2024 06:08 AM
Hi Rodnunes,
What's wrong with the document in message #13?
07-03-2025 08:53 AM - edited 07-03-2025 09:19 AM
Hello everyone! Thank you for sharing your knowledge. I’m trying to control a dpi620 but when I connect the usb232 adapter to the calibrator and connect it with a null modem cable to another usb to rs232 and to my laptop I get a continue output message in my terminal from calibrator “*ir?:82” does anyone have any idea if there is something that needs to be change in the calibrator in order to accept commands?
