DRUCK DPI 610 Drivers
Dear Jack.
I'm also looking for some instructions (commands manual) or drivers for DPI615 calibrator, mainly I would like to readout values or at least files from calibrator.
I have some LV experience with Druck DPI150 and PACE, but for DPI615 I do not have any datasheet or manual to build driver. I believe that in basics it should be similar to DPI 610.
If you can share these instructions or diver I would be very thankful.
Kind regards. Jure
Message 11 of 18
(2,753 Views)
I know this is an old thread.
I have a DRUCK DPI620 and would like to be able to connect to it and pull live data. Does anyone know how?
Message 12 of 18
(2,678 Views)
It is possible to control the DPI620 over a serial port connection to a PC using DUCI commands.  Use a USB to US232 converter on the USB A port on the 620 (not the mini-USB port).  COM port settings 19200 8N1, CR+LF termination, DUCI programming commands attached.
Message 13 of 18
(2,427 Views)
Hi Jack,
Sorry for bringing up such an old thread, but I'm looking for the DUCI protocol to use with my DPI 610... I read that you had to remove the original link to the file, if possible, could you share the info about the protocol in some other way ??
Message 14 of 18
(1,591 Views)
Hi Jack, sorry to bother you, but can you still send the PDFs about the protocol ? I've sent you a PM.
Thanks !!
Message 15 of 18
(1,572 Views)
Hi Andrew,
do you mean USB to RS232? If not can you supply a link with the proper cable. if Yes how should I connect from serial rs232 to usb A port pins TX RX and GND to GND D- and D+ of usb?
Thank you!
Message 16 of 18
(812 Views)
Hi Rodnunes,
What's wrong with the document in message #13?
Message 17 of 18
(809 Views)
Hello everyone! Thank you for sharing your knowledge. I’m trying to control a dpi620 but when I connect the usb232 adapter to the calibrator and connect it with a null modem cable to another usb to rs232 and to my laptop I get a continue output message in my terminal from calibrator “*ir?:82” does anyone have any idea if there is something that needs to be change in the calibrator in order to accept commands?
Message 18 of 18
(436 Views)
