Breaking a string into parts
I have a case like this
aaaaa,bbbbb,ccccc,ddddd,
The a, b, c, and d values are not the same on each read, different lengths
I need to remove the 4 commas and split the 4 segments out seperatly to use as variables in an equation.
How can this be accomplished?
Thank you in advance.
Message 1 of 9
(3,735 Views)
Use Spreadsheet String to Array.  Make the type a 1D array of whatever you data type you want (string, integer, floating point).  Set the delimiter to be a comma.  For the format, it depends on the data type you want.  For a string use %s, for an integer use %d, for a float use %f.
Message 2 of 9
(3,734 Views)
try that baby
Message 3 of 9
(3,713 Views)
That baby is a little too young for me...  😉
Bill
CLD
(Mid-Level minion.)
Message 4 of 9
(3,701 Views)
Lots going on inside the 2012 version.  I guess it would save time versus strining all that stuff up...  🙂
Bill
CLD
(Mid-Level minion.)
Message 5 of 9
(3,699 Views)
use scan from string with regex
Message 6 of 9
(3,682 Views)
Hi, there is another way to accomplish by using Spreadsheet String to Array.
Message 7 of 9
(3,676 Views)
this had already been mentioned...   Smiley Wink
Message 8 of 9
(3,666 Views)
XD...I didn't notice it, sorry to my carelessness....
Message 9 of 9
(3,662 Views)
