Breakout Board for PXI-4304
NI 783870-01
Terminal Block, TB-4304, Front Mount, PXIe-4304/5 Analog Input Module
783870-01 - Ni - Terminal Block, TB-4304, Front Mount (newark.com)
Does anyone know if there is an aftermarket version for board on amazon?
something like this.
Electronics-Salon DB37 D-SUB DIN Rail Mount Interface Module, Male/Female, DSUB Breakout Board.: Ama...
please help. thank you
Krispiekream
(1,508 Views)
Accepted by krispiekream
The front panel connect for 4304 is 96-pin male DIN 41612/IEC 60603-2 connector and searching for that in google brought up this one https://www.winford.com/products/brkn4296.php
Now you need to find a way to keep the connector securely connected to the 4304 for reliable signal connection. This is where NI's breakout board excels as it comes with a metal enclosure that screws to the PXI module and make a robust connection. Or find a long enough extension cable for that connector with the signal shielding that gives you the expected signal integrity (nope, not all cables are the same for all applications).
Santhosh
Soliton Technologies
(1,493 Views)
The manual says that device uses a "96-pin male DIN 41612/IEC 60603-2 connector".
I think this might be what you are looking for:
I can't find it or an equivalent on Amazon though.
Edit: Beaten to it by seconds by Santo...
(1,491 Views)
Thank you for your help, guys. that's very helpful.
Krispiekream
(1,481 Views)
