I am trying to send data from a Rabbit Microcontroller (RCM3600) through the serial point, I am recieving the data correctly, but the buffer is filling up and then the data is shifts one place over, the buffer indicator that I have set only goes up to 8191 for some reason, even if I set the buffer at 1024, I am using the PDA module to do this, I am sending it to a HP5550
