Scaling with FP input
My Input range is 0 to 20mA and the Scaling range is 0 to 2500. I am using cFP 2010 with AI110 card for analog input. In MAX i am able to find the input type only. How can i make the scaling.is it i have to do programatically in Labview.
with best regards
R.sathiyanarayanan
(3,145 Views)
yes, the scaling has to be performed programmatically in LabVIEW. All you can choose from MAX is the input Range and/or type and the Filter setting.
Otherwise, if you are running VI Logger, you may also want to create a Filedpoint Task and see if you can apply your custom scale in the VI Logger calculated channels.
Alessio D.
(3,145 Views)
