[Bug] Bound control in front panel group loses binding when copied
I thought I'd report this bug, only to discover it was reported almost six years ago (in LV2010). CAR #298993 was raised, but the bug is still present in the LV2017 beta. Any time frame on a fix?
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(3,103 Views)
As a note, it works if you select several items and drag-copy them. It's related to grouped copy.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,061 Views)
I'm not sure if we're talking about the same issue. I've attached a VI with a bound control, grouped with some text (the "RMS" subscript). If I ctrl+click+drag the grouped item, then check the binding properties of the new numeric indicator, it's now unbound (and the little binding LED indicator disappears).
Similarly if I ctrl+click+drag the grouped item (or simply copy/paste it), deselect the group, then select the group and click+drag to move it around, the binding LED indicator also disappears.
(3,048 Views)
Michael,
I was able to reproduce this from the VI you attached.  I will take this to some of our product specialists to see if I can provide any feedback here.
Adam
(3,033 Views)
Michael,
Also as a side note, please use the dedicated Beta forums to post your questions related to this version.  All bug reports are being tracked there.  You can find out more about this here:
http://forums.ni.com/t5/LabVIEW/Announcing-the-LabVIEW-2017-Beta-Program/td-p/3567123
Adam
(3,023 Views)
@Mada_17 wrote:
Michael,
Besides beta bugs being tracked there, isn't it not allowable to even be discussing the beta outside the beta forums?
Bill
CLD
(Mid-Level minion.)
(3,011 Views)
