Bug? Picture Ring proprty String and Values" returns error 1054 in LV 8.5
Should that propert exist for a Picture Ring?
Ben
Message Edited by Ben on 09-01-2008 07:47 AM
Message 1 of 9
(5,187 Views)
Depends on what your definition of "should" is. Smiley Wink
It's not limited to 8.5. Also, if you don't wire an indicator to the property there's no error. Since the control is essentially a ring, the properties for the "Ring" class apply, and that's one of the properties. It's just that the property doesn't make sense for a picture ring. I suppose NI could create a separate class for the picture ring NI or could code it so it doesn't return an error if it's dealing with a picture ring. Of course, that would probably start a debate on whether or not it should return an error since the property is technically invalid for that control.  Smiley Happy
Message 2 of 9
(5,163 Views)
Hi there
I'd say "no, it should not". The error vanishes when removing the "Strings & Values" indicator, and it vanishes when replacing with Text&Pict ring (well, that makes sense then). There's a strange coercion dot at the indicator (see your shot). Exactly the same thing with 7.1.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 3 of 9
(5,145 Views)
The fact that the error is gone when you don't connect the indicator is good. Even better it is super.
It means the compiler removes that specific node from the execution stack if it isn't needed.
Ton
My LabVIEW Ideas
Message 4 of 9
(5,136 Views)
Ton
Agreed. LV will not execute nodes whos outpt is not used.
This node would be OK for the sister object "Picture ring with text" but is not appropriate fo rthis object.
(What I'd really like see is NI convert this node to "Values and images". Smiley Wink
Ben
Message 5 of 9
(5,125 Views)
You've all hit this nail on the head.  Not much left to cover here, besides the following:
This was reported to R&D (# 124796) for further investigation.
Thus, we will let the powers that be decide how to deal with this.  As always, thanks for the feedback!
Brian A.
Applications Engineer
Message 6 of 9
(5,099 Views)
Thank you Brian.
Ben
Message 7 of 9
(5,090 Views)
Do I take it from what I have just read here that there is absoluteley no way to programatically update the values of a picture ring at run time then??? - I'm trying to find a way and I just cant seem to find it.
Actually I'm just trying to display a picture in a defined area on the front panel at run time, I thought the picture ring would allow me to do this, but I still haven't worked out how to get anything other than a blank white box yet as the documentation is rubbish.
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 8 of 9
(4,775 Views)
Accepted by topic author Ben
You are correct that a Picture RING can't be populated at run time. On the other hand a Picture can be updated.
THis thread has a lot of links to Picture examples.
These tags may also help getting started with the LV Picture.
have fun!
Ben
Message 9 of 9
(4,765 Views)
