Bug Report: lv2010; Inconsistent value returned from sub-vi
I would think that this has all the qualities of a bug and not a wolf cry
as the behaviour remained even with a good dose of rewrite of the vi
and also swapping the positions of the Terminal with the local variable eliminated the inconsistent behaviour.
michael
Message 21 of 27
(1,587 Views)
michael
After years of reporting and logging LV bugs, I have found that even after a CAR (Corrective Action Report) is filled R&D may come back and tell me they fixed a bug and the new behaviour is correct.
So we have to wait and see.
Ben
Message 22 of 27
(1,584 Views)
@Ben wrote:
Sorry I don't recall that bug.
Thank you,
Ben
I'm not saying that previous thread was a bug, just something about having a terminal in case structure cause a difference in behavior of the subVI that the LabVIEW programmer wouldn't be expecting.
Maybe it was a matter of an indicator terminal that did not execute would return its default value vs. a value from a previous run of the subVI when the terminal may have been executed.
Something I thought I read in the past that I can't remember any details on, and I just am not getting the right search terms together to find it again.
Message 23 of 27
(1,577 Views)
Perhaps you are referring to the "Clear as Mud" post?
Message 24 of 27
(1,575 Views)
That may be it.  I had read it before.  I'll have to read it again to see if it is it.
I did find another thread that seems to be related to the issues in this thread, particularly read messag3 4.  I am sure this isn't the one I was looking for because it was marked as "new" to me, and was posted a couple years before I started working with LabVIEW and participated on the forums.
http://forums.ni.com/t5/LabVIEW/Local-variable-behaviour-different-with-panel-open/m-p/81012#M49675
Message 25 of 27
(1,571 Views)
It is not exactly related, but I never get tired of that post.
Could be some optimization new to LV10 having unintended consequences.
Message 26 of 27
(1,564 Views)
Accepted by Michael.Proctor
@Ben wrote:
Hi Micahel,
I am slow to say bug because "boy who cried wolf" but based on Bill's gut feel, I have requested an App Engineer follow-up. It may take a couple of days for them to complete the work, so standby.
Thank you,
Ben
I've confirmed the symptoms in LV 2010 and 2009, and agree that this is definitely not expected behavior. I've catalogged and submitted it to R&D under CAR# 256324.
FYI, confirmed the behavior in Windows 7 x64 on 32-bit LV 2009 and 2010.
Caleb Harris
National Instruments | http://www.ni.com/support
Message 27 of 27
(1,514 Views)
