Bug in 8.2.1: Missing german translation in IIR Cascade Filter with I.C. (CDB).vi
In the german version of IIR Cascade Filter with I.C. (CDB).vi and IIR Cascade Filter with I.C. (DBL).vi the objects of the element Filterstruktur of IIR-Filter Cluster should be called "IIR zweiter Ordnung" and "IIR vierter Ordnung".
(2,540 Views)
I do not use any german version of LabVIEW and thus cannot check this issue. But if the problem still exists in 8.5 it is worth posting this issue here.
Regards, Guenter
(2,535 Views)
Thanks.
Then I'll check this in 8.5 first and post it there (if the bug still exists) unless somebody else does/did.
Martin
(2,530 Views)
