Bug in Array Function XNodes 1.4.0.24?
I have been using Array Function XNodes 1.4.0.24 for a while now and find them quite useful.
I have however encountered an unexpected behaviour that makes me doubt the filter array node (and thus the whole package).
The "False Elements" output array of the node is too large, filled with elements of identical nonsensical data after the seemingly correct data.
The amount of filler data depends on the boolean array.
My input array is U8. Its size seems to be the problem. If it is smaller by a factor of 100 the vi will work as expected.
Can anyone who has the package installed verify this behaviour with the attached vi?
The package may be downloaded here:
http://lavag.org/files/file/58-array-function-xnodes/
Best regards
Florian
(2,895 Views)
Accepted by Florian.Ludwig
The LAVA CR has a support topic for each upload. You should ask it there - http://lavag.org/topic/10303-cr-array-function-xnodes/
___________________
Try to take over the world!
(2,887 Views)
Thanks for the pointer tst.
It seems a subscription is needed to post there though - requiring a fee which I'm sure I can't communicate to my boss.
"Why do you need to fix something you can do without?"
I guess I'll really just do it without the nodes.
Regards
Florian
(2,870 Views)
Membership in the LAVA forums is free. Just don't check any of the boxes when you create the account. You can pay for a premium membership to support the site, but you don't need it for posting. I would agree that this is a bit confusing.
___________________
(2,862 Views)
It's almost as if they want to sell you something. Smiley Wink
Thanks for clearing that up to me.
Regards
Florian
(2,855 Views)
