Bug in Invoke node - Get VI Hierarchy Image Scaled
I have found one bug ( Am not sure whether it has been already noted ) in the Get VI Hierarchy Image Scaled. for defining the image parameters the Max Height and the Max Width has to be specified but in this case both are dispalyed as Width and when I create a control out of it gives me Height.
Note: This is not only with the LV2011 the same is happening in 2009 also.
(4,679 Views)
You should probably have posted this in the LabVIEW forum and linked it to the monthly bug threadSmiley Wink
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(4,670 Views)
Thanks for reporting this Smiley Happy
It has been submitted as corrective action request #357764.
Peter D
(4,628 Views)
CAR 357764 discussed in this thread has been fixed in LabVIEW 2013. For a more complete list of bugs fixed in LabVIEW 2013, check the LabVIEW 2013 Bug Fixes. You can download an evaluation copy of LabVIEW 2013 at http://www.ni.com/trylabview/ or if you have an earlier version of LabVIEW installed and an active SSP subscription, you will be able to download the latest version of LabVIEW through NI Update Service.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
(4,551 Views)
