Bug in Labview sound system
Then I use the "sound input stop.vi" in Labview 9.x the task ID get invalid afterwards. The use of the latter function works as expected in at least Labview 8.6.
I have made a simple VI in Labview 8.6 to describe the problem
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 1 of 9
(6,542 Views)
hi,
  Maybe it is a bug in pervious versions which is corrected now in labview 9.0...
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 9
(6,535 Views)
srikrishnaNF wrote:
hi,
Thanks and regards,
srikrishnaNF
No it is bug that is introduced in Labview 9.x No problem in Labview 8.6 😉
Message 3 of 9
(6,530 Views)
Hey Coq, the hole LV soundsystem can be considered as a bug 😉
I would love to have a NI LabVIEW ASIO driver ....
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 9
(6,497 Views)
I have the same feeling. But that do not bother NI. They do not care about this part in the Labview development system.
Message 5 of 9
(6,494 Views)
Hi all,
thank you so much for bringing up this issue. I'm sorry for the delay in answering to your post. A week back I created a Corrective Action Request to bring this issue up to our R&D department. This report has our reference; car# 226856.
Martijn S
NI Netherlands
Message 6 of 9
(6,403 Views)
Thank you for taking time to look at my problem Martijn. I solved this temporally by using the 8.6 sound2.dll in Labview 9. The 8.6 sound dll also have some bug. But that will not bother me in this application
Message 7 of 9
(6,376 Views)
Hey "Coq Rouge",
I also replaced my lvsound2.dll and lvsound.dll files ("C:\Program Files\National Instruments\LabVIEW 2010\resource\lvsound2.dll" and "C:\Program Files\National Instruments\LabVIEW 2010\resource\lvsound.dll") with the respective files from LabVIEW 8.6 folder.
But the problem continues with that same Error 4823 in the "Sound Input Read.vi".
What did you exactly do in your workaround, can you explain please?
Thanks ahead!
Vaibhav
Message 8 of 9
(5,872 Views)
Was this resolved? Please let me know, as I am having the same issue and trying to replace the sound.dll files, but having a little trouble.
Nadhi
Message 9 of 9
(5,792 Views)
